<  Tehnika  ~  Ponorela elektronika
OdgovorObjavljeno: Po dec 12, 2011 5:14 pm
Zdravo.
Spet problemi. Octavia I letnik 99, 1.9TDI 81KW. Avtu se je začelo mešat, samodejno se odklepa, zaklepa šipe se spuščajo in ogledala premikajo. Lučka na voznikovih vratih (rdeča) skos sveti. Včasih nemorem ne zaklenit ata ne zapret šip. Sumim ključavnico ali Comfort modul. Ima kdo kakega na zalogi ali kako ključavnico, kje se ta modul nahaja, kaj je to tist ko je pod volanom ??
Lep pozdrav
OdgovorObjavljeno: So dec 17, 2011 12:47 pm
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 5S Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
VCID: 4C9C666E1091017C
Part No: 1U4959801B
Component: 5G Tőrsteuerger. FS0002r
Part No: 1U4959802B
Component: 5S Tőrsteuerger. BF0002r
Part No: 1U0959811B
Component: 5S Tőrsteuerger. HL0002r
Part No: 1U0959812B
Component: 5S Tőrsteuerger. HR0002r
18 Faults Found
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01328 - Convenience System Data Bus
35-10 - - - Intermittent
01334 - Door Control Module; Rear Right (J389)
49-10 - No Communications - Intermittent
01333 - Door Control Module; Rear Left (J388)
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
00931 - Locking Module for Central Locking; Rear Right (F223)
54-10 - Incorrectly Equipped - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01038 - Central Locking Thermal Protection
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
28-00 - Short to Plus
01035 - Electric Window Thermal Protection Active; Passenger
27-10 - Implausible Signal - Intermittent
00934 - Electric Window Motor; Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
End ---------------------------------------------------------------------
Napake ki jih najde, se kdo razume kaj v to
OdgovorObjavljeno: Sr dec 21, 2011 6:27 pm
predvidevam da je nekje na pregibu kablov pri vratih kratek stik. tam ko je guma (harmonika) so notri konektorji, pa ti predlagam da preveriš, če je tam vse uredu.
upam da ti uspe rešit problem.
OdgovorObjavljeno: Sr dec 21, 2011 10:46 pm
Popravil sem zadevo. In sicer modul v voznikovih vratih, ki se drži motorja za odpiranje oken, je bil prepojen z vodo, zamenjal z rabljenim in stvar dela ko nova.
