Objavljeno: Pe sep 11, 2009 10:17 am |
Citiram: List of the most common VW standards
* VW 500.00 – VW spec for multigrade engine oils for petrol engines with SAE 5W-X/10W-X viscosity for engines built up until August 1999 (MY 2000). * VW 500.00 + 505.00 – Oil meets both VW 500.00 and 505.00 spec. * VW 501.01 – VW spec for petrol engines for engines built up until August 1999 (MY 2000). * VW 501.14 – Brake fluid with low viscosity, VW 2006>. * VW 502.00 – VW spec, oil for petrol engines. Successor of VW 501.01 & 500.00 spec. * VW 503.00 – Long-life petrol engine oil for VW cars with WIV. Meets ACEA A1, SAE 0W-30 or 5W-30. Suitable for the AUDI S4, engines with an output greater than 180bhp should use 503.01 or 504.00/507.00. * VW 503.01 – Special engine oil for some VW petrol engines. SAE 5W-30. Suitable for the Ausi RS4, TT, S3 and A8 6.0 V12. * VW 504.00 – Long-life petrol engines with WIV. * VW 505.00 – Passanger car diesel engine oil, minimum performance level CCMC PD-2. Lists viscosities:- SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max evaporation loss. * VW 505.01 – Special engine oil for VW turbodiesel with pump-injector-unit and for the V8 commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 spec. * VW 506.00 – Special long-life engine oil for turbodiesel engines with WIV, viscosity is SAE 0W-30. * VW 506.01 – Special long-life oil for turbodiesel engines with pump-injector-unit with WIV. * VW 507.00 – Long-life diesel engine oil with WIV. * VW 508.00 – Fuel economy low saps oil in development.
vir: http://www.my-gti.com/7/volkswagen-oils-50400-and-50700
Torej:
standard 507.00 pokrije vse standarde od 505.00 do 506.01 standard 504.00 pa vse od 500.00 pa tja do 503.01
BigM
Objavljeno: Pe avg 27, 2010 9:08 pm |
Simply cleverPrispevkov: 411Kraj: MoravčePridružen: Ne okt 05, 2008 11:58 am
a 507.00 standard pokrije tud 505.1
Objavljeno: So avg 28, 2010 12:44 am |
alezzi
Objavljeno: Ne sep 04, 2011 11:33 am |
| Škoda loverPrispevkov: 217Kraj: logatecPridružen: So feb 24, 2007 4:29 pm
Ker mam servis u kratkem pa men zdej neki ni jasn,v servisni piše da more biti olje 0W-40 VW503.00,ampak tle ste pa napisal:
pa me zanima če je lahko tud 0W-30 oz.5W-30?
Objavljeno: Ne sep 04, 2011 5:37 pm |
Meni že dolgo ni pod roke prišel kakšen 0W-40 .. no, vsaj ne s temi standardi katere sem jaz iskal (507.00)
Pomojem bo 5w30 vredu .. sicer pa poglej na tisti listek če so ti ga pustil notri, kateri je bil zadnjič notri tankan ..
alezzi
Objavljeno: Ne sep 04, 2011 8:21 pm |
ja ponavad so dal 0W-40,enkrat sm opazu pa tud 5W-40,sam tale 0W-40 je drag k žafran
Objavljeno: Ne sep 04, 2011 8:34 pm |
Zdej nevem kateri motor imaš, ampak jaz sem mel že dva avta z skoraj 300k km, oba skos tankana na aral longlife 5w30 (507.00) ... Brez problema bilo vse. Sta bla pa oba dizla, to je res. Nevem, pozanimaj se pri dealerju.
