<  Testi vozil  ~  Test Škoda Octavia RS vs Accord 2.4 i-VTEC TYPE S
OdgovorObjavljeno: Ne dec 11, 2005 5:49 pm
Ok no Honda Accord 2.4 i-VTEC TYPE S 4dr technical specification
Performance
0 to 60 mph (secs) False
0 to 62 mph (secs) 7.9
Engine Power - BHP 190
Engine Power - KW 140
Engine Power - PS True
Engine Power - RPM 6800
Engine Torque - LBS.FT 162.3
Engine Torque - MKG 22.4
Engine Torque - NM 220
Engine Torque - RPM 4500
Top Speed 142
Engine and Drive Train
Camshaft DOHC VVT
Catalytic Convertor True
CC 2358
Compression Ratio 10.5:1
Cylinder Layout IN-LINE
Cylinders 4
Cylinders - Bore (mm) 87
Cylinders - Stroke (mm) 99
Engine Layout FRONT TRANSVERSE
Fuel Delivery MULTI POINT FUEL INJECTION
Gears 6 SPEED
Number of Valves 16
Transmission MANUAL
Skoda Octavia 1.8T RS 5dr (Pre-model) specification
Performance
Engine Power - BHP 180
Engine Power - KW 132
Engine Power - PS False
Engine Power - RPM 5500
Engine Torque - LBS.FT 173
Engine Torque - NM 235
Engine Torque - RPM 1950
Top Speed 146
Camshaft SOHC
CC 1781
Compression Ratio 9.5:1
Cylinders 4
Cylinders - Bore (mm) 81
Cylinders - Stroke (mm) 86.4
Fuel Delivery TURBO INJECTION
Gears 5 SPEED
Number of Valves 20
Transmission MANUAL
Evo test!
Če pa kdo ne vrjame, vam še dam strani polek!
Škoda Octavia RS: http://www.buyacar.co.uk/technicalSpeci ... 1298.jhtml
Honda Accord 2.4 i-VTEC TYPE S: http://www.buyacar.co.uk/technicalSpeci ... 3163.jhtml
1 prispevek
